Front wheel bearings
Finchyman
Post by Finchyman » Wed Oct 14, 2020 5:13 pm
Afternoon, are all front wheel bearings the same throughout the Princess production run, or were there part alterations?
Ian
Princess 2.2 HLS. 'Hector'
Jaguar XJS - C. 'Roger'
Jaguar XJ Portfolio. 'Mallory'
Daily driver - The train
Re: Front wheel bearings
Post by Gasman » Wed Oct 14, 2020 6:54 pm
Good Evening.
I reckon the front bearings were the same from 18-22 to Ambassador. Same part number GHB193 for P1, P2 and Ambo.
Finchyman
Post by Finchyman » Wed Oct 14, 2020 8:21 pm
Thank you. Got an advisory on the MoT today and if I maintain this annual mileage I may need to get the bearings seen to in 15-20 years time.
Ian
Post by beiderbecke » Wed Oct 14, 2020 9:13 pm
They are adjustable but there is only a choice of two split pin holes and the nut is tightened to 200 ftlbs (272 Nm) - tight! Some testers these days are not aware of this and it will appear the bearing has failed. Not so - see if it will tighten to the next pin hole. Otherwise leave it as it is and check the free play periodically.
